Genesis 3 Female Corset Dress Not Working?
Hello,
  I recently been using this Corset Dress for Genesis 3 Female: https://www.daz3d.com/corset-dress-outfit-for-genesis-3-female-s. But now, everytime I tried to put on Genesis 3 Female (custom morphs including Girl 7 and Aiko 7 morphs) it won't fit on properly!! The Bolero is on but when I tried to move the arms it is not attached to the arm, it just stay put while the arms is moved. Can someone please help me with this problem? Thank you
  • felisfelis Posts: 6,502
    I don't have it.
    But the way you are describing it, it sounds as if it worked previously, but now it don't.
    If that is the case, have you then tried re-installing it?
  • Yes I did but still not working right for some odd reason.
    felis said:
    I don't have it.
  • Are you sure it is fitted to the figure?
  • mr clammr clam Posts: 707
    I loaded the whole outfit to Aiko 7 and it's working fine for me.
  • Well I tried it again on a normal Genesis 3 female and it still didn't work. Here is the picture of the Bolero.
    1800 x 1286 - 1M
  • LeanaLeana Posts: 13,501
    It doesn't look like it is fit to the figure.
  • Even if loaded with only the Genesis 3 Female in the scene the Bolero fits correctly for me (I had wondered if it might be wanting one of the other items in the set as a target, given that it is in islaotion in your screen shot)..
  • Alright it finally worked. I had to do the daz3d install manager to reinstalled it instead manually installed myself. Thank you all for your help. :)
