dForce hair do not show up anymore
daybird
My problem is, the https://www.daz3d.com/classic-long-hair-with-dforce-for-genesis-8-females do not show up anymore in the smart content.
Even a reinstall and a Re-Import from the Metadata did not bring a result.
I use the newest version of the beta build.
Does it show in the Content Library pane under Daz Studio Formats? Does it show in the non-beta version? How did you install?
I always install with the DIM and yes it shows up in the Content Library, but in the beginning it also was visible in the smart content.
I did not have installed the normal version of DAZ, so I can not say if it works there.
When I rethink about it, I mean I have installed a Plugin or update for the hair, but that was a while ago and I'm not sure about that.
So, this does sound like a database issue - when you look at the files in the Content Library pane do they have their content type flags at top-right (Actor, Hair, Materials and so on)?
No it's all blank (see attachment) and I only can find it over the search function.
OK, so for some reason it isn't in th database at all by the look of it. Can you find it in the Content Library Products list - it will prsumably be in the second run under d, isntalled items are listed before uninstalled.
Maybe I'm to dumb, but I found no entry in the content Library, even when I know it must be there, because the product is listet when I search for it. -.-
So you are actually going to the Products container in the Content Library>C>and scrolling through looking for Classic Long Hair in the list of containers?
Yes, I also have searched for dForce and Genesis 8 things...but did not found it -.-
EDIT UPDATE: Finally I took the hard way, I reseted my Database and now the Hair showed up...bad thing, I have to reinstall a lot now^^
