Orestes iray skydomes, are they convertable to 3DL?
srieschsriesch Posts: 4,243
edited December 2019 in The Commons
Does anybody know if Orestes various iray skydomes are easily convertible to 3DL for use as a simple backdrop on a skydome (even if the HDR effect does not convert)?  Can I just take an existing 3DL skydome and swap out the image used from one of the iray ones, or is it not that simple?
Post edited by sriesch on
  • The HDRs should work with uberEnvironment, though you'd have to set them up manually.
    I took a regular 3DL skydome(using the DS default shader) and loaded an HDRI, rendered with the standard 3DL renderer:
    It won't emit light in this case but can be used as any jpg or png.
    800 x 600 - 495K
    Post edited by Sven Dullah on
  • Oso3DOso3D Posts: 15,114
    My advice would be to take the HDR into, say, Photoshop and convert it to 8 bit, adjusting the image to taste. That way you can get EXACTLY the backdrop you want in 3dl.
  • srieschsriesch Posts: 4,243
    Thanks all!
