Duplicate formula found in files?
I'm getting a loading message "Duplicate formulas found in files. Check to see that content is properly installed". This happens when I load a specific scene. What does it mean? How can I fix it? I tried looking at the log and can't make sense of it
If it's only in the scene, not when you load the base, then it suggests you modified or added some links between properties (e.g. use ERC Freeze on something) - does that sound familiar?
I removed dforce properties from Yeti hair, and I think used freeze simulation on a couple of d-force items. If that's what you mean?
Freeze Simulation does a very different job, so I'm pretty sure it is innocent. How did you remove the dForce properties?
In the simulation tab there's an option to remove them. But you're right, I think I found the actual culprit instead. Thank you.
