How Can I Create a Normal Map as a Material Shortcut???
Can you tell me how to save my favorite Normal Maps, like I would any Material Map, so that I could
apply that normal map to other characters and not override their current material map?
Bear in mind that a normal map from one set of textures may not look good with another. That said, save a Materials preset and in the options dialogue that opens after setting the file name you can uncheck everything and then check just the normal map settings.
Thank you so much! That does it!
