Programming shortcuts to toggle between two dimension presets
[email protected]
Basically I'm wondering if there's some way to program a hotkey to toggle between two dimension presets. I've taken a look in the "customize" menu but can't see a way to do it there.
Thanks!
For which application, and what do you mean by dimension presets?
Sorry for the delay!
For DAZ Studios.
Under "Render Settings" and then "General" you can choose the Dimension Preset (Global). Ideally I'd want to make a custom shortcut that could switch between two of them at the press of a button.
File>Save As>Render Settngs preset, enter the name, then in the options dialogue uncheck General Render and the engine-specific group, then expand General Render>General>Dimensions and check Dimension Preset. Check that works if you chnage he values, I think it should. Assuming it does, right-click>Create Custom Action and choose where in the Scrpts menu to plae it. Repeat fo the other setting. You can, if you wish, use Window>Workspace>Customise to add the commands to another menu or tool bar - find their entis on the left (under Custom Actions) and drag into the emnu or tool bar on the rght that you wish.
