an error occurred while executing save as
DiomedeDiomede Posts: 15,457
Ouch. Has anyone else gotten this. Is there a way to save anyway? Will I lose everything since my last save if I exit?
And yes, that is why I entered my current WIP as my final entry for the monthly challenge.
    Will a plain old Save command work? Or does that message crop up no matter what you do?
  • de3ande3an Posts: 915
    edited February 2014
    I get the same thing quite frequently. I've found that if I dismiss the error dialog box and try to save a second time, the save succeeds. (I'm on a Mac.)
    I've attempted to report this to DAZ, but of course they can't reproduce the problem.:-S
    Edit: Also, see this thread that I started last October on the same subject.
    http://www.daz3d.com/forums/discussion/30636/
    Post edited by de3an on
    Thank you!
    That thread had a great suggestion by Wendy. I was able to group everything (except scene settings), then drag to the browser. Note, I still got the error when trying a simple save, or repeating save as after consolidating shaders, etc. But the group plus browser suggestion worked. Of course, I will have to redo the scene settings but that isn't as big a deal.
  • 3DAGE3DAGE Posts: 3,315
    Hi All :)
    This error is usually because something in the scene has been removed but still has some dependencies, whether that's an object you've deleted, or a texture set you've changed several times...
    Before saving, make sure that you clean out any deleted items or changed-out material sets by using the
    Edit / Remove unused / Objects ... then Shaders, etc
    Hope it helps
  • ShelLuserShelLuser Posts: 749
    Another possibility (but one which most likely won't occur that often) could be memory usage. Now, I think most of you will run DS while making sure that not too many other programs are running, but I figured I'd mention it anyway.
    I've been in situations in the past where I had these errors and it turned out to be memory related. I closed most other programs which were running in the background after which I could save normally again. In the mean time I've increased my memory amount (and a new version of DS has also been released) so these days I haven't experienced that problem.
  • SileneUKSileneUK Posts: 1,980
    3DAGE said:
    Hi All :)
    Hope it helps
    Hey...where have you been!!! Missed you loads!
    xxxxxxxx ;) SileneUK
