is there a handy cheat sheet of right click magic and keyboard shortcuts?
MistaraMistara Posts: 38,675
i think there was a way to apply a material to a whole figure with a right click?
i want to make M6 all gray and set every setting surface setting to 0?
  • Takeo.KenseiTakeo.Kensei Posts: 1,303
    There was a gray skin preset for Genesis and I guess it still exist. I don't know if you can encounter problems but you could try to convert that skin preset to Duf and corret whatever you want in the preset, save it then apply it to M6.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,507
    I know I have done it.
    I did resave the Daz default as a new shader inc materials with the grey diffuse to do it
    edited February 2014
    setting myself up for a weekend of torture, pleasure/pain :lol: trying the shader settings one at a time :)
    when i click on M6's 'skin' in the surfaces tab, it highlights a bunch of mat zones, but not his lips :?
    is there a quick way to select all his mat groups using his limbs jpb only,
    torso, a quick way to select everything using the head.jpg?
    i've found that when i highlight something in the scene tab, when i go to the surfaces tab, it doesn't follow what's selected in the scene tab, i have to select again.
    Post edited by Mistara on
  • almahiedraalmahiedra Posts: 1,374
    If I understand well your answer:
    Magenta is Template 1
    Blue is Template 2
    Red is Template 3
    Template 4 and 5 for mouth and eye parts
    edit: templates 1, 2, 3 coincides with textures
    489 x 803 - 63K
    502 x 772 - 67K
    488 x 785 - 68K
    500 x 700 - 90K
    Post edited by almahiedra on
    With the Surface Selection tool active, right-click and you can select all surfaces using the same map.
    wowww. THANKS!
    i didn't even know there was a surfaces tool.
  • d-2506203d-2506203 Posts: 2
    I read this thread and I did not see the answer to the topic question. I to would like a handy cheat sheet. Does anyone know where to get one so I can reference it as I learn.
  • JaderailJaderail Posts: 0
    Try the Guide or the Manual...
    http://www.daz3d.com/forums/discussion/32249/
