Disabling shadows on the ground plane
CrystalwizardCrystalwizard Posts: 102
Can anyone explain what settings to modify to keep the default ground plane from showing shadows? I don't mind the plane being there for setting up the scene but I'm really tired of what should be a non-existant object insisting on showing shadows.
For that matter, how do I set the thing not to show up in renders in any way, it's not an object I can select
Post edited by Crystalwizard on
  • IceCrMnIceCrMn Posts: 2,333
    Render Settings>Environment
    Click  the button under "Draw Ground" so it says "Off"
    you can also adjust "Ground Shadow Intensity" to 0 if you would like to have it, but not have shadows.
    I general have it set to off unless I'm just test rendering something and want a ground under it.
