RRRR - Build it and they will come voting thread
Totte
Time to vote!
Anyone can vote, not only those participating in the actual contest. You can vote for any entries except for you own entries, and we vote in two categories, Best and Funniest. Best is more of a traditional render contest voting where funniest more takes the humorous look at the image. Some images have a few lines of text explaining the story behind them, which often helps the voting, specially in the funniest category. Each win (1st to 3rd place) will also give the winner at least one sticky Lucky Bastard pull, which means the next round will be a little harder, see below for how wins and Lucky Bastards are counted. We have changed the dropoff of Lucky Bastards so you will loose at half of Lucky Bastard earned the previous round, and set a maximum of seven LBs affecting your pull, if you have more, you will just pull seven a little longer.
As this is the last one for the year, and the Lucky Bastards will reset at New Years day, no lucky bastards will be counted this round.
Vote here: https://www.surveymonkey.com/r/9FRFJ52
Entries are here: Entries only thread
So, what are we voting about?
Winner in the Best category
- $5 DAZ GC
- 1 item from Totte's (Code 66)'s store (no DOs or Bundles)
Winner in the Funniest category
- $5 DAZ GC
2nd in each category
- $5 DAZ GC
Third in each category
- $2 DAZ GC
The voting starts now, and ends Sunday Jan 12 2020 - at 23:59:59 local DAZ Time
How votes are tallied and summed up:
Voting points: 1st = 5 points, 2nd = 4 points, 3rd = 3 Points, 4th = 2 Points and Tiebreaker = 1 Point.
If an image gets 1st, two 2nd, one 4th and two tiebreakers in a category, that is 5 + 2x4 + 2 + 2x1 = 17 Points
Every image points per category is summed up, and top three is calcutaled in each category. As we now have five prizes, a maximum of two entries from the same artist can end up top three in each category, this is to spead the joy a little more.
The image with most points from the same artist will be the base, the the average score for up to for other images will be added to that score, but if that image takes a top three placement, images who got to the cream of the crop with help from other entires, will gain extra LBs based on how many places it climbed, minus one. Here are two examples:
Example 1: The top image from X has 15 points. X also has five other images that has been voted for, 10, 8, 7, 7 & 5 points. Thaking the average of the first four images behind the top one is 10+8+7+7 = 8, so the first image which was at 4th place, now gets 23 points and rises to the top and becomes the winner. But, that image climbed 3 steps, so it will not only win, but give the winner 3 LB for the next run.
Example 2: The top image by Y has 11 points, and the second image 9 points. The top image will now have 20 points and go from 5th place to 3rd place, granting Y 2 LB for the next run.
If two images ends up with the same score, we use the same rules as in the European Song Contest, the number of higher scores wins over many lower scores, so if one image has 5+5+5+1 (16) and another has 2+2+4+4+2 (16) the first one will come before.
To avoid votespamming, anyone voting needs to post here in this thead that they did vote, and use the same name as they have posting here as the DAZ Forum name in the first question in the vote system at SurveyMonkey.
Remember to vote in both categories and place all five votes in both categories. Votes that fail to vote in both categories and votes faling to vote 4th to 5th place will be discarded.
I voted and let me tell you it was a very hard decision!
i voted and i agree with saphirewild
Voted - exceptional work, folks.
I voted. Thanks, Totte. Good theme and renders.
More votes!
Vote and get a cookie!
LOL!
or vote and get an easter egg?
Sorry I didn't get time to enter, but I voted.
(Do we get to choose between the cookie and the egg?)
I vote that you add all the prize money together and divide it by 3 Do I get the easter egg now.
But Chohole - you are the hen that made the easter egg!
Closed!
being as I live in Wales are you suggesting I am an old bird
No, an old dragon ;-)
that would be y draig hen
Winners announced!
https://www.daz3d.com/forums/discussion/379321/rrrr-build-it-and-they-will-come-winners-announced
