Main content folder huh?
harryfelder615harryfelder615 Posts: 15
So I have been working with the sculpting program suclptris and I imported a daz model to it and just before I started sculpting I noticed the eye lashes, I tried to removed them in sculptris and that failed, then I tried removing them in daz studio 4.6 and I could not, next I tried removing them in Bryce 7.1 and although it worked the problem was once I imported the model into sculptris....how do I explain this? the model just looked different and I did not like how it looked I tried to make it look better but gave up, last I tried putting it in blender to see if I could get rid of the eye lashes that way but for what ever reason the only thing that I could edit was the pupil of the eye. So after all these attempts failed I looked around the interweb and found a morph that hid the eye lashes I downloaded at and the read me told me to save it in the main content folder I looked every where and could not located the content folder, does such a thing event exist? HELP ME PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • CyberDogCyberDog Posts: 232
    Mine is located at mydocuments/daz3d/studio/mylibrary/content
  • harryfelder615harryfelder615 Posts: 15
    Yeah I tried looking it up and that is what I keep getting but when I go into documents then daz 3d then studio then my library there is no content folder
  • fixmypcmikefixmypcmike Posts: 19,718
    There shouldn't be a folder named "Content" under "My Library" -- "My Library" is the name of the content folder.
    Inside DAZ Studio, go to Edit > Preferences > Content Library > Content Directory Manager, and you will see the path to your DS Formats content folder there.
    Thanks everyone for your advice, and although(for what ever reason) the morph did not work when i put it the content folder I still value the advice and I finally found a way to remove the eye lashes without messing up the model.
  • JaderailJaderail Posts: 0
    My friend you have NESTED content folders here. This is a KNOWN cause of many errors when working with DAZ Studio.
    Yep I forgot about not having a content folder there. The odd thing is DIM installed it there. I will have to submit a ticket to get the file updated.
