Edit--Figure--Zero--Zero Figure Pose not working
I have a Genesis 3 Female figure based on Cai for Mei Lin 7. She lives in my Scene Subset library wearing Carly Heels G3F. When I remove her heels, her feet will not go back to standard flat pose regardless of how many times I manually reset every single bone in both her feet to zero. Edit-->Figure-->Zero-->Zero Figure Pose leaves all her settings in the Parameters pane showing at Zero, but she is still in a high heel pose.
Does "Zero Figure Pose" mean what it says, or not? Is it possible for a creator to do this deliberately i.e. to change the foot pose of a character to a high heel pose, but then tell Daz "from now consider her feet to be at zero"? If I put her shoes back on, her feet are at a totally impossible angle pointing straight down, and her toes at 90 degrees to her feet. And it seems nothing I do can correctly reset her feet to zero.
Could this be a specific behavior of the Carly Heels product? Can I ask this of the creators, Arryn-3DSublimeProductions-outoftouch?
  • LeanaLeana Posts: 13,498
    My guess would be that there's a foot morph applied, hence why "zero pose" doesn't change it.
  • cm152335cm152335 Posts: 421
    i already encouter the problem of bad formed toes after apply shoes
    it's frustrating that i can fix until a reload again the character before apply shoes
    note:
    when you create a new character,
    always use MEMORISE POSE and SHAPE, sometime toes are fixed with zero
  • dijituldijitul Posts: 146
    Try using just "Zero Figure" instead of Zero Figure Pose.  It may be a shape morph.  Also, you can select the character then go to "Currently Used" under the Parameters tab and see if any other morphs are applied.  Also, if you memorized a pose/shape/figure, imaybe it resets to this instead of going to "zero."
