Is there a way of resetting xyz axis for a figure.
blue6stringblue6string Posts: 60
Sometimes I get in a bind where. Translation and rotation of the character is on the diagonals. In other words when I want to translate up, instead of going straight up. The figure moves up at a 45degree angle (example only). Is there a way that you can reset these axis with out changing the pose of the character?
  • Richard HaseltineRichard Haseltine Posts: 111,842
    If you are using the viewport controls try going to the Tool Settings pane and use the options at the top of the pane to change the coordinates used. Alternatively parent the item to a null (Create>New null) and use that to move it around.
  • blue6stringblue6string Posts: 60
    Thanks! Creating the null and parenting is a nice solution because you can always unparent
    And have the original axis's available... Thanks!
  • If you are using the viewport controls try going to the Tool Settings pane and use the options at the top of the pane to change the coordinates used. Alternatively parent the item to a null (Create>New null) and use that to move it around.
    Thank you for making the end of the world a little easier!
