Location of bump files in Bryce.
allanonallanon Posts: 53
edited December 2019 in Bryce Discussion
I've been using Bryce for a few three years and I'm still not certain where the files for the bump effect are located. Can anyone point this lost soul in the right direction?
Post edited by Chohole on
  • HoroHoro Posts: 11,691
    There are no files for the bump effect. A texture can have Diffuse, Bump and Alpha. So when you use a texture, go into the DTE and see whether B (bump) is activated. For a picture texture, you can use the picture for bump but it is not very strong. We experimented some time ago to use a normal map (generated from a picture in an other program) but even then, the bump effect is not actually satisfying. However, with textures it works great.
  • allanonallanon Posts: 53
    Ahh. Thank you, that clears things up. So I'm thinking that I can create a folder for bump files and then refine that process as time goes by. Sound workable?
    You got to try it to see if it's workable for you. It may.
