Best way to move a morph from Genesis 1 to G8F?
HI all,
I have an old morph I used to use on Genesis 1 and I'm trying to move it to G8F. I attempted to follow SickleYield's guide (https://www.deviantart.com/sickleyield/journal/Tutorial-Transferring-Character-Morphs-G1G2G3G8-409437916) however the issue I seem to be running into is that the G1 morph is based off the androgynous G1 base and when it's put onto the G8F model the morph hyperexaggerates the difference and I can't think of a way to offset this issue.
Is there a way to dial G8F into the shape of G1 first?
  • nicsttnicstt Posts: 11,715
    edited December 2019
    GenX and its add-ons. Then I use XTransfer from G3 to G8.
    I have done it manually, but it is time-consuming. Results can also vary.
    Manually transfer, I usually (but not always) approximate the body using morphs, and manually transfer the head.
    Post edited by nicstt on
