an error occured while reading the file, see the log file for more details
I have Easy Enviroment, the winter lake
It worked until yesterday.
Than i made an image.. and before rendering i had to go so i saved the scene.
When i later opened it..everything loaded but not the easy enviroment ...
So i deleted that from the scene and wanted to put it back in .. but since than i get the message
I un installed it.. and used IM again..
I tried to instal in DAZ 4.12 itself (64 bit)... but it will not load any more
What to do
  • LeanaLeana Posts: 13,502
    Well first, check the log file to see what the error actually is.
  • Are you sure you were loading the model, not a preset (which will throw that error is there was nothing in the scene selected)?
