A "gummy translucency" effect on a surface
Hi all
What I'm trying to get here is to put one object inside of another (say, inside a cube) and to change the cube's surface settings (in Iray) so that it's tranculent. I want to be able to see the object inside the cube, but not necessarily all the way through.
Any hints you can give on how to accomplish that?
Thanks!
    edited December 2019
    Not an IRay expert but played with the IRay Uber for a while out of interest. I put a sphere inside a cube and adjusted teh surface for the cube.
    Translucency weight 0,5
    Refraction weight 0.5
    Thin walled off to enable subsurface scattering
    Transmitted color pure white
    Scattering measurement distance 50
    SS amount 1
    And with refraction index at 1 and scattering measurement distance 30:
    ...and a final one with these settings:
    Hope that helps;)
    800 x 600 - 323K
    800 x 600 - 353K
    413 x 726 - 86K
    800 x 600 - 306K
    Post edited by Sven Dullah on
  • OVDOVD Posts: 262
    Thanks so much!
  • HylasHylas Posts: 5,287
    Try IRAY shaders "Wax" and "Jade", they come with the base program.
