influence paint tool in daz?
hi, guys i want to know if DAZ studio have a influence paint tool for outfits??? and how to active and use??,  i means a tool to edit or create new influence in the outfits for the bones, for the characters like what you can dool in tools like maya or Character creator 3 from reallusion
  • The Node Weightmap Brush tool allows editing of weightmaps.
  • EllessarrEllessarr Posts: 1,395
    and how exactly this work, i clicked on the tool then go to the "piece of cloth and it's doing nothing.
  • You need the Tool Settings pane, which will allow you to pick the weight map to edit (for Genesis 3 and 8 that will be the geneal Weights map, for Genesis and Genesis 2 each boen will have multiple maps).
    hmm interesting, what i want is try to edit a "old piece of "armor from V4 to G8, when autofiting it or using the converter tool to fit it into genesis 8, it ending wiht bad influences in a lot of places, then i wanted know if have a way to edit it to fix that bad influences.
  • You would use the Node Weightmap brush for that, along with the geometry editor to help with selection probably. However, you may also need to add some morphs or do othe work beside just weight editing.
