Selection not highlighted
starboard
I am new to Hexagon. I have worked in Infini D for years and I am at last moving up to a new system and new programs and of course, the steep learning curve.
I am building a 17th century naval coat to use on a model in Poser 10. It is progressing fine, using the many tutorials for making dresses which are on line. However I am at an impasse. When I try to make a surface selection, the polygon squares are no longer highlighted. This prevents me in looping, etc. I have referred to the Hex manual but cannot find any switch or box that I may have activated.
Thanks for any help in getting me out of this fog
Starboardtack
Attach picture.
Allega immagine.
Ciao
Bye
Select one or two face normals/squares in a row and then click "l" on the keyboard to "loop".
Hold down the Shift key to add or subtract more faces.
Patience,
Thanks for getting back to me. I know how to select and loop, the problem is when I click on a square it does not highlight indicating that a selection has been made. It was working fine - I was making selections and looping - all was happy, then something occurred, probably me pressing something I should not have, then I could no longer make a selection. I finally saved all and restarted the program, then I was able to highlight and select again. However, now Hexagon has decided to do it again, I'll keep looking in the manual - I must have missed something crucial.
Thanks again,
Starboardtack
try trashing your preference file
Dot_Bat is probably right, but have a look at your preferences first (Edit drop down list) and check to see if the HighLight box is ticked.
Oh okay. That's a different matter. I haven't had that happen [yet] but have had the +/- shift selection go wonky. Solution can indeed be to close/re-open Hexagon. And/or Edit, preferences, reset to default. Close/Open and go back to preferences and fix a few things [like, no need to call home for updates, etc.] Sometimes [but not often] re-booting the computer might help too.
Haven't figured out "why" it goes goofy now and then, but often [at least over here] it happens when opening a file that was created in another program.
