Morphs on base models G3
vvs021088
I messed up something with morphs and I have a lot of morphs on the base model, and they now apply to other characters
I want to remove morphs from the base models. G3
All right. Before removing "all" morphs {cause some are normally pretty good to keep}, would you clarify what you mean by "messed up"? Some characters do call for other morphs in their make-up.
It might be only one morph that needs to be removed, adjusted or replaced.
For major surgery: To fix the morphs:
Go to your Product Library and download the Genesis 3 Essentials Female and/or Male packages.
There are a few folders with morphs in them.
The base collection is:
data\DAZ 3D\Genesis 3\Female\Morphs\DAZ 3D {if these are what need fixing, copy in the new files}
Any additional morphs, presumably the ones you want to remove, should be in folders NOT under this 2nd folder of DAZ 3D.
data\DAZ 3D\Genesis 3\Female\Morphs\Other Name(s) {I would suggest backing them up into a zip folder in case you change your mind or need them again for some reason}
Thank you so much. Everything worked out for me.
Most welcome, happy it worked out for you :-)
