Daz saving stuck at 99%?
Darren556gDarren556g Posts: 4
I'm working on a scene right now, and everytime i try to save the file, it gets stuck at 99%. Sometimes it would say not responding and the program will just crash. Anyone have any idea how i can fix this?
    What OS are you using?
    What version of DAZ Studio, and bit depth, 32 bit or 64 bit?
    What does it say in the log file about any crash that happens? Help > troubleshooting > View Log File.
  • BartlebyBartleby Posts: 58
    I am having a similar problem. I have been using Studio for a year or so, I recently upgraded to the latest version of Studio and have been using it for a few days.
    Suddenly today every time I try to save a scene it gets to 100% on the lower progress bar (Writing Assets) and freezes, reporting 'Not Responding'.
    Empty scenes save OK but as soon as I add something....this.
    I am using Studio version 4.6.2.117
    Windows 7 SP1
    Any help solving this would be appreciated!!
    The bottom part of my log file looks as follows - a few suspect lines in there...:
    DEBUG: initDB!
    DEBUG: Db is Open
    Error writing author data!
    Total class factories: 1318
    WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
    3D mouse support library could not be loaded.
    Creating interface
    Successfully created OpenGL viewport for Viewport1.
    Successfully created OpenGL viewport for Viewport2.
    Successfully created OpenGL viewport for Viewport3.
    Successfully created OpenGL viewport for Viewport4.
    WARNING: QFile::flush: No file engine. Is IODevice open?
    Executing startup script...
    Started in: C:/Program Files/DAZ 3D/DAZStudio4
    DAZ Studio Started
    Creating Pixel Buffer
    Pixel buffer - Width: 1024 Height: 1024
    Compiling OpenGL Shader...
    Fragment Shader:
    Fragment Shader compiled successfully.
    Linking Shader:
    Fragment info
    0(29) : warning C7050: "_rgb" might be used before being initialized
    Shader Program successfully linked.
    Windows 7 SP1
    DEBUG: initDB!
    DEBUG: Db is Open
    That looks like it may be the only thing that is relevant.
    This may sound weird...but have you tried saving to a different folder than the one you usually save to?
    That does look like it may be the culprit. I have tried saving to alternate folders but still no luck.
    I am noticing something odd in my file structure though - when I look at folder properties they are all tagged Read Only, which would explain things, but I am finding that I can write to them anyway using other applications. When I uncheck the box and apply - does not seem to make any difference though, it is still RO when I look again. So it may be a broader OS issue - though everything else seems to be working OK.
    I also note that there is an update to Studio 4.6 in Install Manager so I am installing that too.
    I will keep looking at it and will post here if I solve the problem.
    That sure is sounding/looking like an OS/permissions problem...
    Try right clicking on the DS shortcut and selecting Run as Admin...and then try saving a scene.
  • cm152335cm152335 Posts: 421
    give more time to save!
    Once you got 99% is the time he start to save data on disk!
    My problem was system protected area
    Another time it was about read many lights
    As Mjc propose you, change location (not in a system place)
    and wait more!
  • PekenPeken Posts: 37
    Windows 7 SP1
    DEBUG: initDB!
    DEBUG: Db is Open
    Creating interface
    DAZ Studio Started
    Fragment Shader:
    Linking Shader:
    Fragment info
    Had the same problem (Win8.1 -64) - for me it was the Octane plugin.
    Disable the "non Daz plugins" and check if saving is ok...
    And that would seem to be the problem. Disabled Octane and the problem seemed to go away, enabled it and the problem was back.
    Thanks!!
  • Darren556gDarren556g Posts: 4
    Windows 7 SP1
    DEBUG: initDB!
    DEBUG: Db is Open
    Creating interface
    DAZ Studio Started
    Fragment Shader:
    Linking Shader:
    Fragment info
    Ah, i was just about to reply to my first post in this topic, but after skimping through this topic this method works for me. I also use octane render and disabling it before saving works. THank you.
  • edited December 1969
    I have the same problems, and by turning off the octane plugins, I can save like usual, anyone know how to fix this problems? ( I mean with the octane plugins turned on?)
    I never had this problem before.
    Probably needs to be brought to the attention of the maker of the Octane plugin...and for them to make an update.
    edited February 2014
    Looks like the latest Octane Plugin update fixes this problem, its on the list. I will confirm when I have had a chance to try it out.
    [Edit] Quick test indicates that the update does solve this issue.
    Post edited by Bartleby on
    There you go...
    This happens quite often with plugins. Things may not be changed or so it seems, on the Studio side, but very often some of the 'behind the scenes' stuff does change....usually a newer build of qt. If the plugin uses qt and is a precompiled plugin (as opposed to one that compiles when run), then depending on the version of qt it was built on the update can cause problems. The same thing would happen with a system-wide qt update, too. And sometimes it doesn't always break things...and usually the broken things don't show up on the developers' machines...but after it's been released. (and it's just as bad/worse with Poser and Python updates...)
    Post edited by mjc1016 on
  • JaderailJaderail Posts: 0
    There were SDK updates in the NEW DS4.6.2 so the plugin prob used a SDK call that changed a bit. Causing the error.
  • Richard HaseltineRichard Haseltine Posts: 111,296
    DS 4.5+ plug-ins should still work, but newer plug-ins may not work in older versions of DS.
