Organizing Morphs in DAZ - SOLVED
McKinnanMcKinnan Posts: 0
edited February 2014 in New Users
I've purchased a couple of morph packages. While the packages have THEIR OWN categories under Parameters (i.e. Expressions, Aging Morph, etc..) all the morphs IN those packages seem to be a part of my original morph dials once they are installed.
Is there a way to keep them ONLY in their categories?
EX - Aging Morph "Old Body Bent" shows up under Parameters-Actor. IT ALSO SHOWS UP under Parameters-Actor-Aging Morphs.
I'm not really looking for a filter. I grock those.
I guess I'm looking for an interface preference here or something.
Thanks in advance.
Post edited by McKinnan on
  • Richard HaseltineRichard Haseltine Posts: 111,332
    I'm not sure whether this is what you are asking, but to see only the parameters immediately under the current heading uncheck Show Sub Items at bottom-left of the pane.
  • McKinnanMcKinnan Posts: 0
    Unchecking Show Sub items turns everything off.
    If you select a group with morphs you will see morphs - but a lot of groups are in fact empty.
    I didn't really want to turn a bunch of stuff off. Just wanted to see what is normally in Parameters without the addition of the purchased morph packages dials.
    The only way I can think of to do that is to uninstall, or to set up a new content directory set pointing to an empty location and install only the base to that. looking at the file list should let you see the morph names (in the \Data\DAZ 3D\Genesis\Base\Morphs folder) though that won't give you the paths for the Parameters pane.
    Richard, you are the "answer guy" for sure! That's OK... It is not that critical and I don't want to start playing around with customizing my DAZ installs. I like to keep things simple :-) I was mainly just wondering if there was a "preferences" switch I was missing.
    Thank you!
