Toon Santa problems with Animate Lite
I have studio 4.12 loaded on a Dell Inspiron laptop and an HP desktop. The toon Santa works fine on the HP but on the Dell Santa just jerks around with his arms straight out.
I am using animate lite with the Dance animations
Any thoughts
Are you sure you have the same selection in the scene in both when applying the Aniblock?
there are two sets of dance animations side by side confusingly in the same location, for VMAGFH etc 4 and genesis 8
I did check that the same selections were made. Will do some more tests
Solved the problem. G8m files only on laptop. Santa is not g8m. Installed proper files. Santa works fine
thanks
