simple way of making genesis 8 female look a bit sweaty?
All over her body I mean. I see some 'wet' textures and stuff for sale but I don't think it'd look like sweating as much as someone who's just jumped into a swimming pool. Any suggestions how I could do a simple way of making her look like she's been for a pretty hefty jogging session? I understand I have to adjust the glossiness or something can someone be more direct here? am not sure what to change in the textures. Ty.
  • TaozTaoz Posts: 10,346
    edited December 2019
    There is a thread about oily and sweaty skin here, you can try to play with the shader settings yourself:
    https://www.daz3d.com/forums/discussion/comment/4961531/#Comment_4961531
    Post edited by Taoz on
    With the wet geoshells you don't have to have them at 100%. You can lower the "strength" of the wet effect by lowering the opacity of the shell... best done in Iray preview mode.
  • ToobisToobis Posts: 993
    K but I never purchased the wet skin shaders/mats so I just am after a basic way to give her some sweat look. Can someone pls tell me what to adjust on G8F on surfaces to make this so?
    Basically these ones, but I'm sure there's others.
    The adjustments must be made in the scene you intend to render it in because the scene lighting and environment will probably have more effect on the final look than the adjustments themselves.
    Post edited by fred9803 on
  • HylasHylas Posts: 5,328
    I found this tutorial very helpful: https://thinkdrawart.com/how-to-get-wet-skin-in-iray
    You don't even have to do the 2nd part with the geoshell, adjusting the settings already makes your G8 look a little sweaty.
