decimator plugin won't work with 4.5 (32 bit Windows)
stuartfstuartf Posts: 0
I paid for this plugin in Decemeber and have only just downloaded it.
The install appeared to be successful but it doesn't come up in the tab and when i check the plugins iot gives the following message even thopugh this is flaged as being the 4.5(+) version
Plug-in failed to load!
Filename:
C:/Program Files (x86)/DAZ 3D/DAZStudio4/plugins/dzdecimator.dll
Plug-in:
dzdecimator
Author:
Unknown
Version:
0.0.0.0
Reason:
Plug-in was made for a newer version of DAZ Studio.
  • stuartfstuartf Posts: 0
    I've tried downloading and installed Studio Pro 4.6 64 bit and the 64 bit version of the Decimator plugin seems to works with that OK
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,541
    I believe you only need enter a serial, not download anything
    you might have accidentally replaced the .dll file by doing so, reinstalling studio should fix it
    on a different note, I wish I could get decimator for DS3A too,
    I fortunately have the paid version of the FBX exporter for it because a lot of older Poser figures using parenting simply do not export correctly from DS4
  • JaderailJaderail Posts: 0
    The Decimator in your Downloads will always be the Version for the NEWEST version of DAZ Studio. So if DAZ Studio 4.6 is the NEW version the Decimaor will be for DS4.6. To get versions for older versions of the program you must have Bought the Program in the Past and Decimator for that version. Decimator is a BUY only plugin. And only the Help desk can get the older version for you, so you will need to send a support ticket to the help desk and show that you own the rights to both items to get Decimator for older versions.
