RSSY G2-G3 Clothing converter problems
shadowhawk1
I recently purchased the RSSY G2-G3 Clothing converter and so far I have not been able to convert anything. I am using 4.9 and I kkeep getting this error. I am using an older laptop and can't use newer versions of studio do to video card limitations.
2019-11-27 21:49:18.356 WARNING: fileinput\dzassetdaz.cpp(4639): Could not find node parent.
2019-11-27 21:49:18.517 WARNING: fileinput\dzassetdaz.cpp(1766): Failed to follow node.
2019-11-27 21:49:18.517 File loaded in 0 min 0.4 sec.
2019-11-27 21:49:18.519 Loaded file: Converter Bodysuit.duf
2019-11-27 21:49:18.770 Loaded Morph Deltas in 0 min 0.0 sec.
2019-11-27 21:49:18.964 Loaded file: Converter Morph.dsf
2019-11-27 21:49:18.968 DEBUG: Convert Item is Converter Morph_9579
2019-11-27 21:49:18.982 DEBUG: Item's Compatibility Base Path for Node /Ultra Bodysuit for Genesis 2 Female(s)/Ultra Bodysuit
2019-11-27 21:49:18.982 DEBUG: Presentation
2019-11-27 21:49:18.982 DEBUG: autoFitBase
2019-11-27 21:49:18.982 DEBUG: colorA [object Object]
2019-11-27 21:49:18.982 DEBUG: colorB [object Object]
2019-11-27 21:49:18.982 DEBUG: description
2019-11-27 21:49:18.983 DEBUG: iconLarge
2019-11-27 21:49:18.983 DEBUG: iconSmall
2019-11-27 21:49:18.983 DEBUG: label
2019-11-27 21:49:18.983 DEBUG: Preferred Base /Genesis 2/Female
2019-11-27 21:49:18.983 DEBUG: type
2019-11-27 21:49:18.983 DEBUG: Transfer Morphs, Source is RSSY Genesis 2 to Genesis 3 Converter BodySuit, Target is Ultra Bodysuit
2019-11-27 21:49:19.059 DEBUG: END Conversion of E:/Content/People/Genesis 2 Female/Clothing/Bodysuits/Ultra Bodysuit/Ultra Bodysuit.duf
2019-11-27 21:49:36.828 DEBUG: Execution Complete.
2019-11-27 21:49:51.155 WARNING: Script Error: Line 883
2019-11-27 21:49:51.156 WARNING: TypeError: Result of expression 'transfer.setParentToFigure' [undefined] is not a function.
2019-11-27 21:49:51.156 WARNING: Stack Trace:
<anonymous>()@E:/Content/data/RiverSoft Art/Common/RSLegacyClothingConversionFunctions.dse:883
2019-11-27 21:49:51.162 Error in script execution: E:/Content/Scripts/Clothing Converter/RSSY Clothing Converter G2F to G3F.dse
The vendor is more likely to see your issue if you post it in the product thread in the Commercial Products section
https://www.daz3d.com/forums/discussion/316466/released-rssy-clothing-converter-from-genesis-2-female-to-genesis-3-female-commercial
