repeatable error on daz4.6 wont load
insanetiggerinsanetigger Posts: 5
edited February 2014 in Daz Studio Discussion
Can anyone please help this has been going on a while now. Every time i try to start daz4 it goes through the loading faze even gives me the tray icon but i cant open the main window to do anything. I get a preview of what its doing in the tray but no main window so i cant adjust or sort anything out programme wise
Im running
the latest download of DAZ4.6
AMD phenom QUAD CORE
8 gigram
windows 7 64
extra graphics card
AMD RADION HD 5700
I have attached the log file hoping it might help ok i cant load the log it wont let me
EDITED to add log
+++++++++++++++ DAZ Studio 4.6.1.39 starting +++++++++++++++++
Platform bits: 64
Qt Version: 4.8.4
Running on Windows 7, Build 7601, Service Pack 1
CPU Information:
CPU String: AuthenticAMD
CPU Brand String: AMD Phenom(tm) 9600 Quad-Core Processor
Cache Line Size = 64
L2 Associativity = 8
Cache Size = 512
Stepping ID = 2
Model = 2
Family = 15
Extended family = 1
CLFLUSH cache line size = 64
Supported CPU Features:
SSE3 New Instructions
MONITOR/MWAIT
x87 FPU On Chip
Virtual-8086 Mode Enhancement
Debugging Extensions
Page Size Extensions
Time Stamp Counter
RDMSR and WRMSR Support
Physical Address Extensions
Machine Check Exception
CMPXCHG8B Instruction
APIC On Chip
SYSENTER and SYSEXIT
Memory Type Range Registers
PTE Global Bit
Machine Check Architecture
Conditional Move/Compare Instruction
Page Attribute Table
Page Size Extension
CFLUSH Extension
MMX Technology
FXSAVE/FXRSTOR
SSE Extensions
SSE2 Extensions
Hyper-threading Technology
Physical Memory:
Total: 7.9 GB (8588345344)
Avail: 5.3 GB (5779955712)
Virtual Memory:
Total: 7.9 TB (8796092891136)
Avail: 7.9 TB (8795881275392)
Current Memory Usage: 32%
Current DateTime:
Loc: Sun 9. Feb 04:03:36 2014
UTC: Sun 9. Feb 04:03:36 2014
Temp Data:
Location = C:/Users/Tigger/AppData/Roaming/DAZ 3D/Studio4/temp
Disk Total: 465.6 GB (500000878592)
Disk Avail: 115.3 GB (123828670464)
Locale: en_GB
No translator found.
Reading style definition C:/Program Files/DAZ 3D/DAZStudio4/resources/style/Darkside.style
Creating managers
Reading help index
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/DAZ Studio/DAZStudioHelp.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/EXPExporter/ExPExporter.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/FBXExporter/FBXExporter.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/FigureSetup/FigureSetup.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/JointEditor/JointEditor.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/LayeredImageEditor/LayeredImageEditor.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/MorphLoader/MorphLoader.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/MorphLoaderPro/MorphLoaderPro.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/PolygonGroupEditor/PolygonGroupEditor.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/TextureAtlas/TextureAtlas.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/WeightMapBrush/WeightMapBrush.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/inlinehelp.dsx
Scanning import folders
Scanning content folders
Using GLEW 1.9.0
Supported OpenGL extensions:
GL_AMDX_debug_output : NOT INITIALIZED
GL_AMDX_vertex_shader_tessellator : NOT INITIALIZED
GL_AMD_conservative_depth
GL_AMD_debug_output
GL_AMD_depth_clamp_separate
GL_AMD_draw_buffers_blend
GL_AMD_multi_draw_indirect
GL_AMD_name_gen_delete
GL_AMD_performance_monitor
GL_AMD_pinned_memory
GL_AMD_query_buffer_object
GL_AMD_sample_positions
GL_AMD_seamless_cubemap_per_texture
GL_AMD_shader_stencil_export
GL_AMD_shader_trace : NOT INITIALIZED
GL_AMD_texture_cube_map_array : NOT INITIALIZED
GL_AMD_texture_texture4
GL_AMD_transform_feedback3_lines_triangles
GL_AMD_vertex_shader_layer
GL_AMD_vertex_shader_tessellator
GL_AMD_vertex_shader_viewport_index
GL_ARB_ES2_compatibility
GL_ARB_ES3_compatibility
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_blend_func_extended
GL_ARB_clear_buffer_object
GL_ARB_color_buffer_float
GL_ARB_compatibility
GL_ARB_compressed_texture_pixel_storage
GL_ARB_compute_shader
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_indirect
GL_ARB_draw_instanced
GL_ARB_explicit_attrib_location
GL_ARB_explicit_uniform_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_layer_viewport
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_no_attachments
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_invalidate_subdata
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_draw_indirect
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_query_buffer_object : NOT INITIALIZED
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_seamless_cubemap_per_texture : NOT INITIALIZED
GL_ARB_separate_shader_objects
GL_ARB_shader_atomic_counters
GL_ARB_shader_bit_encoding
GL_ARB_shader_image_load_store
GL_ARB_shader_image_size
GL_ARB_shader_objects
GL_ARB_shader_precision
GL_ARB_shader_stencil_export
GL_ARB_shader_storage_buffer_object
GL_ARB_shader_subroutine
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_shadow_ambient
GL_ARB_stencil_texturing
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_bptc
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_gather
GL_ARB_texture_mirror_clamp_to_edge : NOT INITIALIZED
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_levels
GL_ARB_texture_query_lod
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_snorm : NOT INITIALIZED
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_transform_feedback_instanced
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_attrib_binding
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_10f_11f_11f_rev : NOT INITIALIZED
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_envmap_bumpmap
GL_ATI_fragment_shader
GL_ATI_separate_stencil
GL_ATI_texture_compression_3dc
GL_ATI_texture_env_combine3
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array
GL_EXT_copy_buffer : NOT INITIALIZED
GL_EXT_copy_texture
GL_EXT_direct_state_access : NOT INITIALIZED
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_histogram
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_specular_color
GL_EXT_shader_image_load_store
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_EXT_subtexture
GL_EXT_texgen_reflection : NOT INITIALIZED
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_bptc : NOT INITIALIZED
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod : NOT INITIALIZED
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_rectangle
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_shared_exponent
GL_EXT_texture_snorm
GL_EXT_texture_storage : NOT INITIALIZED
GL_EXT_texture_swizzle
GL_EXT_timer_query
GL_EXT_transform_feedback
GL_EXT_vertex_array
GL_EXT_vertex_array_bgra
GL_EXT_vertex_attrib_64bit
GL_IBM_texture_mirrored_repeat
GL_KHR_debug : NOT INITIALIZED
GL_KTX_buffer_region
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_copy_depth_to_color
GL_NV_copy_image
GL_NV_explicit_multisample
GL_NV_float_buffer
GL_NV_half_float : NOT INITIALIZED
GL_NV_primitive_restart
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
GL_SUN_multi_draw_arrays : NOT INITIALIZED
GL_WIN_swap_hint
WGL_EXT_swap_control : NOT INITIALIZED
WGL_ARB_extensions_string
WGL_ARB_pixel_format
WGL_ATI_pixel_format_float
WGL_ARB_pixel_format_float
WGL_ARB_multisample
WGL_EXT_swap_control_tear
WGL_ARB_pbuffer
WGL_ARB_render_texture
WGL_ARB_make_current_read
WGL_EXT_extensions_string
WGL_ARB_buffer_region
WGL_EXT_framebuffer_sRGB
WGL_ATI_render_texture_rectangle
WGL_EXT_pixel_format_packed_float
WGL_I3D_genlock
WGL_NV_swap_group
WGL_ARB_create_context
WGL_AMD_gpu_association
WGL_AMDX_gpu_association
WGL_ARB_create_context_profile
WGL_NV_DX_interop
WGL_NV_DX_interop2
WGL_NV_float_buffer
OpenGL features for current hardware:
OpenGL provider: ATI Technologies Inc.
OpenGL renderer: AMD Radeon HD 5700 Series
OpenGL version: 4.3.12618
Maximum number of lights: 8
Number of auxiliary buffers: 4
Number of texture units: 8
Depth buffer bit resolution: 24
Maximum OpenGL texture size: 16384 x 16384
Current OpenGL Texture Quality Setting: High Quality
RGBA color bitplane resolutions: 8 8 8 8
GLSL version: 4.30
Shadow mapping supported
VBO supported
WARNING: dzvalentinaobjectdatabase.cpp(38): DB Register Open error: Cannot establish VC_Connection with remote server.
Make sure the server address and port number are correct.
*** Scene Cleared ***
Loading plug-ins:
aniMate2.dll
dazscriptide.dll
dz3dconnexion.dll
dz3dmouse.dll
dzalignace.dll
dzassetiofilters.dll
dzautofit.dll
dzautoriggerbasic.dll
dzautoshaderbakeractions.dll
dzbrycebridge.dll
dzbvh.dll
dzcolladax.dll
dzcomponents.dll
dzcontentdbeditor.dll
dzcontentlibrarypane.dll
dzcr2exporter.dll
dzcustomizedlg.dll
dzdecimator.dll
dzdelightrenderer.dll
dzdformeditor.dll
dzeasyloader.dll
dzexpexporter.dll
dzfbxexporter.dll
dzfbximporter.dll
dzfiguresetup.dll
dzgoz.dll
C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzgoz.dll failed to load. Cannot load library C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzgoz.dll: The specified procedure could not be found.
dzhexagonbridge.dll
dzimageio.dll
dzjointeditor.dll
dzlayerededitor.dll
dzlayerfilter.dll
dzmanualshaderbaker.dll
dzmaptransfer.dll
dzmorphfollower.dll
dzmorphloader.dll
dzmorphloaderpro.dll
dzobjexporter.dll
dzoptitexclothbasic.dll
dzpolygongroupeditortool.dll
dzprimitives.dll
dzpropertyhierarchyeditor.dll
dzpuppeteer.dll
dzpz3importer.dll
dzrenderedit.dll
dzrenderlibrary.dll
dzrslshadercompiler.dll
dzsavefilters.dll
dzscriptedrenderer.dll
dzscriptedsteps.dll
dzshaderbaker.dll
dzshaderbuilder.dll
dzshadereditor.dll
dzshadermixerbase.dll
dzshadermixergui.dll
dzsmartcontentpane.dll
dzspotrendertool.dll
dztextureatlas.dll
dztransferutility.dll
dzu3dexporter.dll
dzweightmapbrush.dll
dzwinvideo.dll
lamhPlugin.64.dll
sdk_sceneinfopane.dll
dzdrawstyles.dll
dzpowerpose.dll
Total class factories: 1226
WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
3D mouse support library could not be loaded.
Creating interface
Successfully created OpenGL viewport for Viewport1.
Successfully created OpenGL viewport for Viewport2.
Successfully created OpenGL viewport for Viewport3.
Successfully created OpenGL viewport for Viewport4.
WARNING: QFile::flush: No file engine. Is IODevice open?
Executing startup script...
Started in: C:/Program Files/DAZ 3D/DAZStudio4
DAZ Studio Started
Creating Pixel Buffer
Pixel buffer - Width: 2048 Height: 2048
Compiling OpenGL Shader...
Fragment Shader:
Fragment Shader compiled successfully.
Linking Shader:
Shader Program successfully linked.
Loading Startup Scene : G:/Daz3d/Studio/People/Genesis/Genesis.duf
WARNING: fileinput\dzassetdaz.cpp(5344): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/MCMV4EyesClosedR.dsf.
WARNING: fileinput\dzassetdaz.cpp(5344): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/MCMV4EyesClosedL.dsf.
WARNING: fileinput\dzassetdaz.cpp(5344): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/MCMM4EyesClosedR.dsf.
WARNING: fileinput\dzassetdaz.cpp(5344): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/MCMM4EyesClosedL.dsf.
WARNING: fileinput\dzassetdaz.cpp(5344): Duplicate formula found linking Value & CTRLFlirtingMasculineR in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Expressions/CTRLFlirtingMasculineR.dsf.
WARNING: fileinput\dzassetdaz.cpp(5344): Duplicate formula found linking Value & CTRLFlirtingMasculineL in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Expressions/CTRLFlirtingMasculineL.dsf.
WARNING: fileinput\dzassetdaz.cpp(5344): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/MCMV4HdEyesClosedR.dsf.
WARNING: fileinput\dzassetdaz.cpp(5344): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/MCMV4HdEyesClosedL.dsf.
WARNING: fileinput\dzassetdaz.cpp(5344): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/FHMVictoria4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5344): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/FBMVictoria4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5344): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/MCMM4HdEyesClosedR.dsf.
WARNING: fileinput\dzassetdaz.cpp(5344): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/MCMM4HdEyesClosedL.dsf.
WARNING: fileinput\dzassetdaz.cpp(5344): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/FHMMichael4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5344): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/FBMMichael4.dsf.
Post edited by insanetigger on
  • JaderailJaderail Posts: 0
    Sometimes (I Think) Daz fails on dual GPU card PC's. Think you must pick the one DAZ Studio will use before it loads. Never ran dual but have heard of some such error. Hope another with more info can pop in to help.
    I'm Not seeing anything POP out as the cause. But I'm not sure of ALL the Errors I just read.
    Post edited by Jaderail on
  • insanetiggerinsanetigger Posts: 5
    I think most of them are duplicate faults ive been living with them cos you only have to hit ok and daz continues to load. Im not actually running dual well i dont think i am lol. The problem started about a month ago so ive gone back to using daz 3 for now. Thank you for looking Jaderail
  • Richard HaseltineRichard Haseltine Posts: 111,984
    Judging by the duplicate formula alerts you have a really old set of files for the morphs - you need to redownload and reinstall the Michael 4 and Victoria 4 shapes for Genesis. I don't think that will help with crashing though.
    Also there is an error with the CMS...
    Could resetting to the default layout possibly help?
    That should prevent the start up scene from loading...I'm not 100% sure which file needs to be removed, Richard should know...since a start scene isn't loaded by default, resetting should remove that as a possible cause.
    The Duplicate ID's did not bother me as much as the OpenGL errors. I'm not sure but think the content errors would not prevent the interface from loading. If you Remove the Content folder fully, just move it to a different folder, and try to open DAZ Studio and it still does not open it is not content related. If it does open then it is the content, which you could just install again. Try that and lets see.
    Those OpenGL 'errors' look about 'right' for the AMD card installed...and most of the content errors are dupe formula errors, not dupeID.
    Dup Id, Dup Formula, to me neither one should crash the interface load. That was the point. That means moving the Folder(s) so DAZ Studio does not see it/them at boot to test if it does cause the error. If not it has to be the OS at some point.
    The two problems are the zbrush plug-in and CMS, uninstall them.
    Sorry its taken me so long to come back but im a very unwell at the moment.
    Would un-installing DAZ4 and daz's cache help or would that cause more trouble?
    Ive tried un-installing the CMS and deleting the default scene as well as restarting my comp after doing thr first 2
    Unfortunately this did not work
    What i dont understand is Daz$ was working fine untill the
    I'm really greatful for everyones help as im really stuck on this matter
    :blank:
