Recently bought the formal mega wardrobe for genesis 8 female(s)
comixfanacomixfana Posts: 278
I'm not clear on how to tuck the blouse/bodysuit inside the skirt/pants?
Also, I thought (I must have misread) it came with a pair of shoes...it doesn't, d'Oh!  I've been trying to (unsuccessfully) fit Victoria 4 pumps on my Genesis 8 female figure...rather unsuccessfully. I'm faking it using the Bardot sandals which I've colored black using a shader (looks like a pair of strapless heels!).  Wrapping the blouse and blazer around my character's rather "disproportionately large bosom" has been a head scratcher too - I get full coverage by cranking the "voluptuous" slider all the way up, but then the bottom part becomes too baggy...agreed, that will be a non issue once I've fgured out how to tuck the blouse/bodysuit, it shouldn't be visible at that point...
Oh yeah, I did try to fix it by reducing the breasts size from an E cup to a D cup, but I'm having the same problems...
If you could point me to the appropriate setting(s) it would be much appreciated!  And if there's a pair of pumps for Genesis 8 females I could get for cheap, it would also nbe much appreciated!
Thanks!
Post edited by comixfana on
  • The pants have a "fit-overblouse" morph (with named morphs for each top in the set). Set it to 100%. the blouse has a "fit-inpants" morph. Set it to 100%. That should get you close (for highly morphed characters you may need to adjust the adjust morphs to get it right.
  • comixfanacomixfana Posts: 278
    edited November 2019
    Thanks! Oh, is the "fit over blouse" setting also be available for the skirt?
  • No idea. I just loaded the outfit and checked both pieces for fit morphs.
