Add bones in the hips
Hi everyone is it possible to add bones in the hips on a daz models like it's been done in this video ?
https://www.youtube.com/watch?v=1Qa__hBkwxQ
I would like to make it in daz if possible to do.
Thanks for your help by advance
That's how the pectorial; bones are done. Ypu can add a new bone with the Joint Editor - select the hip (or perhaps the pelvis), then right-click>Create>New Child bone as I recall (I think you'd want ZYX for the rotation order). Then use the joint editor to place the centre point. Once you have the bone placed you need to use the Node Weightmap brush tool to paint on its influence - bear in mind that adding weight to your new bone will remove it from whatever currently influences the area, which is why i thought the Pelvis might be a better parent (because then the jiggle boens will still move with the Pelvis).
Thanks you very much Richard I will try this and see if It work good for me :)
I will tell you soon how it goes.
