Kelly Lodge Props Problem
I used to use props from the Kelly Lodge set quite a bit.  But now, after a few DAZ/Studio versions have come and gone I can't find the section where you can choose separate props from the set to use as you please.  There's a separate category for materials and then there's a couple of choices for choosing the whole gigantic set all at once.  I *know* I used to be able to choose individual props from the menu.
Does anyone have an idea as to how to get the prop menu back for that product?  If not, is there a way to save those props individually?
  • NorthOf45NorthOf45 Posts: 5,921
    The individual props and groups of them are in the Poser version. The DS version loads everything, as you noticed, but also has the DS materials presets for all those pieces. So, load them from the Poser folders and apply the DS materials. You can use as is, or save as figure/prop assets. This will create DS-native versions with the proper surface settings for future use.
    Or, load the big scene and save out the individual pieces and/or groups. They would load at their current position, so you might want to move them to the origin if you don't always want them in the same place. Either way is a fair amount of tedium (118 props and groups), but you only need to do it once.
  • TallulahdahlingTallulahdahling Posts: 387
    edited November 2019
    Thank you so much, NorthOf45!  I'll give all of that a go.
    Post edited by Tallulahdahling on
