Board Games - small mistake on GO board
is there any way to contact the maker of the http://www.daz3d.com/board-games ?
there is a small mistake on the GO BOARD that is made for this pice...
there are 19 squares, when there should be only 18 squares (which means 19 lines - 19 cross sections where you can play)...
and that would also fix the problem with the "DOTS" that are placed on some of the cross sections...
the 1 line with dots is the #4... and the next one is on the 10th line... which places all the dot on the correct area...
http://www.cs.cmu.edu/~wjh/go/rules/AGA.html
http://en.wikipedia.org/wiki/File:Blank_Go_board.svg
I hope that help IMPROVING AN ALREADY AWESOME PRODUCT
if I had the PSD of the original board I could fix that, but without it I would "hurt" the texture that is already done around the lines
Contact technical support
https://helpdaz.zendesk.com/requests/new
support ticket submitted
