Solid colors?
Is there a way to get parts of my character model in solid colors? For example, I want my character to have solid gray skin, and I want the hair to be solid black.
  • AJ2112AJ2112 Posts: 1,417
    Yes, in surface tab, remove maps or use solid shaders.
  • Could you explain exactly how this is done? Maybe with some screenshots? I can't seem to find either of these two options.
    Sure, will shortly.
  • carrie58carrie58 Posts: 4,183
    Can you find the Surface Tab?
  • The base genesis 1 model loads solid grey by default into Daz Studio.
  • GordigGordig Posts: 10,865
    Genesis 8 also has dev load options, which load untextured.
  • llastffirst1234llastffirst1234 Posts: 55
    edited November 2019
    carrie58, yes, I was able to find the surfaces tab. I just couldn't find the options that AJ2112 was directing me to. Also, I should mention that I need this in view port mode. I don't need it as a render.
    Post edited by llastffirst1234 on
    okay so are you using Iray or 3Delight? Any way load your figure and select it in the scene tab ,then in the Surface tab click on the figure again in Iray find Base color click on it and a window pops up that has a list of all the maps  being used ,at the top of the list it says Browse and None click on None , that just got rid of all the maps ,now click on the color bar ,of Base color and make it what ever color you want . In 3Delight you are pretty much doing the same thing only it's called Diffuse,go through the same steps, and there you go .When you need the regular skin texture back just reload it .
    Post edited by carrie58 on
    Hello friend, did a quick step by step for you.
    Step 1 - In surface tab, you can choose any surface to modify.  For example, I select face > base color
    Step 2 - Use mouse to hover over drop down box, you will see mapped image.
    Step 3 - Click on drop down box, click None.  Map will be removed.
    Step - 4 is solid results you desire.
    You can do this with any surface, hope this helps.
    2673 x 1080 - 727K
    2665 x 1080 - 726K
    2619 x 1080 - 746K
    1674 x 1080 - 215K
    Post edited by AJ2112 on
  • scorpioscorpio Posts: 8,534
    You will find the surfaces tab under
    Windows>Panes(Tabs)>Surfaces
    1388 x 850 - 132K
    Small question. My tabs are on the side, how do you get them to show on the top?
    Took me a few minutes to find it,
    Windows>Workspace>Orient Tabs Along Top
    Thanks yes
