Will 'Ideal Beauty for G2F' and 'Beautiful Bends for G2F' conflict?
CypherFOX
Greetings,
I'm considering getting one or both of these, and they both talk about how the additions are automatically included... I was wondering if they would conflict with each other, and over-correct, or something like that, if both were installed?
I know that's vague, but I don't entirely understand the mechanism underneath tools like this.
-- Morgan
I would also like to know this...
Automatically included means the dials for those morphs will automatically be added to G2F, just like every other morph. You still have to dial them in and have full control over how much of each morph is used. Conflict shouldn't be an issue.
Greetings,
The way I read the descriptions, the morphs themselves don't get dialed in by the end-user (me), they are automatically controlled by how much I bend a joint, for example.So I'm picturing a pair of morphs, both of which are controlled by how much I bend the forearm, both 'fighting' over how sharp to make the elbow...
If you're fairly confident that's not how it works, I'll believe, since that's not something I know enough about...
-- Morgan
Each of the products got a master controller, which can be dialed down.
Edit: And to answer the other question, if both are fully enabled it gets kind of weird ;) Depends on the pose and render as to which I choose.
Hi,
The corrective morphs are all rigged so they are enabled when you move the limbs and other body parts. Generally, you don't need to do anything at all but pose the figure(s).
I don't have the Ideal Beauty product, so I can't say Beautiful Bends for G2F is 100% compatible with it. However, users and testers have said that they can work together, provided you don't use both products at full strength (100%). If I remember correctly, he was using a mix of 70% BB G2F and 20% with Ideal Beauty,
You can use the master dial to control all the morphs or if you prefer, fine tune each joint to find the best combination that looks best to you..
