Product says it is... Shopping Cart says its not
MJ007MJ007 Posts: 1,718
Im trying to purchase the Elevator Hallway. Shopping Cart says its nothing in it. But when I go to add the item, I keep getting the dreaded, "Shopping cart doesnt allow a maximum over 1 stop it or we will eat your children" kinda message. Ive refreshed, cleared cache, cntl-f5, etc.... HELP?
-MJ
  • Charlie JudgeCharlie Judge Posts: 13,628
    edited February 2014
    Try this; it usually solves the problem.
    Add another item (any item) to the cart. Cart should now show two items. Remove the unwanted item you just added and you should still have the one you want showing in the cart.
    Charlie
    Post edited by Charlie Judge on
    But make sure that you a re fully logged into the store first.
    The reason this happens seems to be that you are logged into the forym but have been logged out of the store, because that times out after a while, unlike the forum.
  • Miss BMiss B Posts: 3,071
    I had the same thing happen to me earlier with the Elevator Hallway, and I did exactly what Charlie suggested. I threw one of the items in my wishlist in, and then deleted it when both items showed up in my cart.
    I believe I was logged into the store this time, or at least I looked and it said I was logged in, so not sure if that was the problem or not.
    Post edited by Miss B on
  • MJ007MJ007 Posts: 1,718
    Thanks all. Adding a new item to the cart and then deleting it done the trick.
    -MJ
