WARNING from Daz studio log file?
Kharma
Can anyone tell me what this means? It shows in the logfile at the end of every render and I have no clue how to get rid of the warnings ...
2019-11-16 10:09:22.244 Finished Rendering
2019-11-16 10:09:22.285 Total Rendering Time: 17 minutes 34.97 seconds
2019-11-16 10:09:22.308 Loaded image r.png
2019-11-16 10:09:22.362 Saved image: AppData\Roaming\DAZ 3D\Studio4 Public Build\temp\RenderAlbumTmp\Render 1.jpg
2019-11-16 10:10:37.881 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2019-11-16 10:14:58.015 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2019-11-16 10:19:39.488 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2019-11-16 10:24:46.957 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2019-11-16 10:30:13.419 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2019-11-16 10:35:57.964 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2019-11-16 10:41:57.441 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2019-11-16 10:47:51.189 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2019-11-16 10:54:02.649 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2019-11-16 11:00:24.164 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2019-11-16 11:06:46.660 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2019-11-16 11:13:20.131 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2019-11-16 11:13:52.072 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Device statistics:
2019-11-16 11:13:52.072 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (GeForce GTX 970): 1800 iterations, 5.227s init, 1044.410s render
2019-11-16 11:13:58.095 WARNING: Object::disconnect: Unexpected null parameter
2019-11-16 11:13:58.095 WARNING: QCoreApplication::postEvent: Unexpected null receiver
2019-11-16 11:13:58.204 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Tcp shutdown called on a Tcp connection without a shutdown
2019-11-16 11:13:58.750 Iray [INFO] - IRT:RENDER :: 1.1 IRT rend info : Shutting down irt render plugin.
2019-11-16 11:14:20.095 *** Scene Cleared ***
