Reinstalling/Locating after resetting Windows
Due to poor performance recently on my PC, I had to reset it and reinstall Windows. I knew going in that I'd have some issues with getting Daz set back up, but it's truly being a pain. Is there a good way to handle this to get everything back to where it was? Should I use the install manager to uninstall everything, and then put them back on? Should I go into my folders and just delete everything with "Daz" in the title and then install fresh? What's the best way to go about doing this?
I assume the issue is that your assets don't show up in smart content? If so you may need to delete everything and let DIM reinstall it all.
The issue is that I can't even find the program to start it up.
Have you reinstalled the software? That will be necessary after a Windows reinstall, even if the application files are still there, as far as I know (DS1 and 2 were portable, I don't believe 3 and 4 are).
