Send to zBrush [solved]
Hey All,
I am strugling with GoZ - Bridge between DAZ and zBrush. After updating DAZ to 4.12 the 'Send to zBrush' menu item disappeared.
What I did so far (After searching the net):
- Emptied zBrush cahce (Preferences/GoZ)
- Re-set the paths in zBrush
- Re-installed goz plugin in DAZ
- Re-installed DAZ
- Re-installed zBrush and Goz in zBrush
Nothing worked :(
I don't see 'Send to zBrush' even under Window/Workspace/Customize/Bridges.
Do you have any idea what the problem could be?
Thanks in advance,
Adam
Post edited by gulyo on
Are you sure that the DS and GoZ versions match - both the same release channel, both the same bit-architecture, both the same version?
Almost sure.
- Windows 10 Pro
- DAZ: 4.12(64 bit), GoZ 4.12+ (64 bit) - installed from install manager
- zBrush: 2019.1.2 (64 bit), Goz 1.9.0.86 (64 bit)
When I start an export from zBrush it opens DAZ correctly, but after that nothing happens. So I suspect it's around DAZ.
Is the plug-in listed, and does it have a greeb plug icon, in Help>About Installed Plug-ins in DS?
Argh, the plugin was not enabled...
Thanks a lot, you saved my life - or at least the life of my morphs and pislacement maps :)
