What I would like to see added to DS.
in The Commons
Would it be possible to add the Carrara render engine to DS? Carrara has a distinctive and interesting render image quality, often a beautiful quality. So DS has 2 render engines now; why not make it 3? This would simplify a lot of things. I guess there must be big problems in this... otherwise it probably would have happened by now.
Thanks.
https://www.google.de/amp/s/www.dailymail.co.uk/sciencetech/article-7684467/amp/Sci-fi-holograms-step-closer-reality-scientists-create-floating-3D-image.html
how about supporting this display? :D
sorry, couldn't resist
...direct 3ds and .lwo format import.
A $9.99 a month subscription program that grants complete free access to all products in the entire DAZ store, for all purposes. Also, I want a unicorn, a box full of moon rocks, and the original footage for the missing spider pit scene from the 1933 King Kong,
Unicorn https://www.daz3d.com/da-unicorn-for-daz-horse-2
And I want the option to explore/setup scenes inside DS in VR, but you know what they say about wishful thinking.
...Daz soon?
Oooo... and add Sketchup .stl files and, as long as we're asking for the moon, .vob and .max.
Oculus Rift support, go go go.
..yeah that too, however, those often still need to go to a modeller to fix errors like ngons, back facing polys, and just sloppy work.
Carrara is not getting any update and this seems to be the pattern for it as DAZ goes.
It is only a matter of time until it can't be used any longer, but the render engine is beautiful, and it would simply be very convenient to put it in DS..
