Unwanted artifacts in render issue
Hello, I'm getting these artifacts on the forehead. It's not the skin file, I checked. And it's across different G8F figures. They're easy to erase in Photoshop, but I'd like to figure out what the glitch is. Can anyone pinpoint the problem?
  • FishtalesFishtales Posts: 6,233
    It is the skull cap for the hair, it shows in some and not others. Either hide it or shrink it a little and see if that sorts it.
  • PadonePadone Posts: 4,322
    edited November 2019
    It may be the scalp geometry. You may try rendering without the hair to verify this. If it's the hair then you may try scaling up the scalp to avoid geometry intersections with the head, or using the scalp fitting morphs if there are any. Or you may use another hair set that doesn't have issues.
    Post edited by Padone on
  • Might be the scalp, yes. This one in the draft does have one, but the artifacts show up in another figure with completely different hair. I'll check it out, thanks.
