Ghostly Grey Lines and Models?
Hello! I'm trying to get started with DAZ studio, but there's some sort of major problem with how everything looks on my computer. The grey grid in perspective view (and all models I add), blur into a complete mess whenver I move the viewpoint. Here is an example attached. All I did was add a model, delete it, and then move the view slightly. Rather than having a clean perspective view, the ghost of the model plus crazy grey lines are everywhere.
I assume this must be a common problem because I just installed the software. But I can't seem to google a fix/explanation. Does anyone know what's going on? Thanks for any help!
(I have a ~$700 gaming laptop that does most visual stuff well enough, even if it's not top of the line. I assume it might be a hardware issue.)
I've removed the image as, beneath the artefacts, the figure was naked.
This is most often that the system has two GPUs - an Intel GPU on the CPU and a stand-alone GPU from AMD or nVidia - and is using the default Intel GPU. If you open the nVidia/Catalyst Control Panel (depending on make) by right-clicking on the Desktop you should be able to tell the system to use the stand-alone GPU for Daz Studio.
Thank you! You were correct and I fixed the problem. (Sorry about the image; it won't happen again.)
