Copy and paste primatives?
Simply, I have one primative that I've sized and shaped and shaded. I'd like three more ove the exact same thing. Is there a way to do this? One might think that copy/paste would be the way to go but that's not how it works in Daz land from what I can see...but maybe I'm overlooking something.
Thanks in advance!
Edit: See...I post the question so that my brain will give up and just figure it out. Same menu. Duplicate Nodes did what i needed. Well, that was a thrilling end to a difficult question.
Post edited by Aabacus on
Copy/paste in DS is used specifically for translation/rotation, etc values, which makes sense when you think about it. Duplicate Nodes is used when you need copies with different materials. Alternately, in the Create menu, try New Node Instances (set the number of instances you want in the dialog). In terms of resources, instances use far less, but be aware that changing the material on the original, will also affect all the instances
Save the primitive as scene subset
