can u combine figures from different generations?
can you load characters into a scene from say genesis 2 male and victoria 4?
just doing some research.
thanks
    Yes,...you can load basically any figure, at the same time, in the same scene...from very early ones to the latest,
  • edited December 1969
    thank you. that was very helpful.
  • CybersoxCybersox Posts: 9,960
    One qualifier: you can as long as the figures are all compatible with the software you're using. If you're working in the newer versions of Poser you can use Anastasia, Rex, Roxy, etc., with Genesis via D-SON, but you can't use the weight-mapped Smith Micro figures in DAZ Studio 4.X. Of course, you also can't use the Smith Micro WM figures in the older versions of Poser, either. And while Dawn can work in either system, a lot of her add-ons will only work in one program or the other.
  • JaderailJaderail Posts: 0
    I often use many types of figure generations in one image to get what I want. This one is M4, Genesis1, G2F V6 HD and many of the LowRez figures all in one image.
    1125 x 1462 - 3M
