Moving escalator?
Is there an escalator available for purchase or freebie that has steps that can be moved?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,760
    edited November 2019
    Depending on how handy you are with a modelling program you could take something like First Bastion's mall and fiddle with the escalator mesh and chop it up.
    you only need to remove a top or bottom step then shift the other steps up or down scaling that one step as a separate prop each end
    mm now wondering if it has an ecalator
    I have bits from CGAxis including an escalator I probably used with it
