Do I need to install PostgreSQL CMS +Beta+ ?
I just installed Daz Studio 4.12 Beta.  (As well as the corresponding  Photoshop Bridge, Measure Metrics, Goz, and Scene Builder).
Do I need to install the PostgreSQL (Wind 64-bit) Public Build Beta and the Conversion Beta also?  the latter seems unnecessary as I haven't used valentina.
Thanks for your help.
Currently, DIM appears to be "searching" endlessly.
  • MelanieLMelanieL Posts: 7,825
    edited November 2019
    You only need to install one version of PostgreSQL, the correct one to install is the main version (product id 18869) - the beta version (product id 18868) is now redundant (I am a little surprised it appears in the DIM at all).
    If you never used Valentina, then no - you do not need to install the conversion.
    Post edited by MelanieL on
  • It's always possible thata  future version of PostgreSQL might be released as a beta, but it is true that theya re the same right now - and that you will be able to have only one isntalled at any time (trying to install another uninstalls the one that was there).
    You don't need the conversion tool at all, unless you haev an old Valentina database. DS has not used Valentina since 4.10, or even 4.9, and DIM no longer supports it - in fact I am told that the conversion tool will soon stop appearing in the downloads. (As an aside, it doesn't really "install" - the conversion was done while it was being isntalled, and all that was added afterwards was a marker to show that it had been used.)
