Viewport display issue - "ghosting" effect
Hi.
I'm getting a "ghosting" effect in the viewport whenever I move the camera or objects in the scene (I've attached a screenshot).
It's like the viewport doesn't refresh.
Does anyone know how to fix this?
  • Richard HaseltineRichard Haseltine Posts: 110,526
    edited November 2019
    The image had to go as it showed a nude figure - it would have been better to zoom to show only the head.
    This is usually the result of using an Intel GPU for the display - if that's all your system has you may be stuck, but if you have both an Intel GPU on the CPU and a stand-alone nVidia or AMD GPU make sure that DS is using the latter. For nVidia that's in right-click on Desktop>nVidia Control Panel, and I believe the same is true of AMD (you then want the Catalyst Control Panel).
