Is there a way to render through the floor?
I happen already several times wh nI try to render completely legit scene only to get either completely black screen or just the environment map if any. And every time I start to scratch my head and to look for camera position and settings to evade the floor.
I don't know why this was introduced but is there a way to turn it off and to get normal renders as they look into 3D viewport?
  • NorthOf45NorthOf45 Posts: 5,896
    Sounds like you are rendering in Iray from below ground level. Turn off the ground in Render Settings->Environment->Draw Ground to OFF.
    Thanks!
