GamePrint: 3D Print Plugin hide parts I don't want in my printable figure?
Aaron-HCG
in The Commons
Is there a way I can get rid of the hair "frizz" in my printable figure? ( 3D printers can't print with very small thickness)
Also the hair cap remain in the head last time I download my stl in the site how do I hide this in daz?
What I want is how do I skip mesh parts I don't want to show up in the printable figure with daz studio? I mess with surfaces tab "opacity" making the slider to 0 but still showing up in the final STL.
1200 x 1200 - 456K
1200 x 1200 - 399K
800 x 600 - 1M
Hello Heaven - Decimator should do a pretty good jobe of that.
You need to use the geometry editor and delete the polys you don't want printed. Most hairs have a separate scalp texture, so Geometry Editor, then go to tool settings and you should see surface and groups to select by. Click the + next to the surface you want to remove, and then right click in the viewport and edit, remove or delete selected polys
Thank you so much! it works by using geometry editor
