Full screen browse issue?
raphaelmartines
It happens when I click on browse, in any category, the option takes all the screen! Any suggestion?
Version 4.12 beta
Thank you!
1896 x 800 - 357K
That just means you have a lot of texture files in use in that particular scene. The only way to "fix" it is to delete some things, then the texture list will be shorter.
Seems that Daz is just formatting the "columns", to be as wide as the largest images "name". Like it doesn't know that the other names in the other columns can fit in a smaller column width. Don't they normally display a drop-down list?
Does it do this when you are not in full-screen mode? If not, than I would open a help ticket to report the issue.
I don't think this can be resolved by resetting the UI, so I am not going to attempt to suggest that type of fix. This seems like an internal code issue.
It doesn't matter if I have one or thousand textures, the issue happens with any scene. Like JD Mortal said, sounds like an issue and must be reported. Thanks for helping.
