Michael 8 Applied to Every G8 Male Character
I recently noticed that every male character I load from eith my library or that were saved in a scene file have Michael 8 head and body morphs set to 100%.  Not sure how or why this is happening, has anyone else experienced this?
  • LeanaLeana Posts: 13,430
    That means you gave installed or created a shape using the M8 morph and saved with non-zero default value, so it loads automatically.
    Have you installed a character for M8 recently?
    Thank you for the response.  I did save a character earlier in the day today.  Is it possible to undo this?
    You need to find the morph responsible for the problem, then change the default value setting in its parameters, then resave the asset.
    I will give this a try, thank you!  :)
  • It didn't work, I re-saved the character I had saved earlier in the day (making certain that the Michael 8 morphs were off) but still every male character loads with Michael 8 head and body morph at 100%.  :(
    It's likely you saved over the Genesis 8 Male. Look there.
  • You could try reinstalling Michael 8 - if you did somehow chnage its default value that would restore it. However, I think it's more likely that an add-on character is setting the Michael 8 shape - if you click the gear icon on the Michael 8 slider and select Parameter Settings what, if anything, is listed in the Controllers tab at the bottom of the dialogue?
