Genesis Supersuit - manual download - several files broken!?
XoechZXoechZ Posts: 1,102
Hello!
When I download the Genesis Supersuit (manual download - I do not use DIM!) and try to unzip it, I get an error message that several files cannot be unziped because they are broken. I have not counted them but I think that there are at least 10 to 15 broken files in the zip file.
I have tried to re-download several times and it is always the same, so no download error.
But the suit and all shaders seem to work, so I do not know what these broken files are good for. Seems to work without them :-)
Can anyone confirm this? Or is it a known problem?
    I have never seen that problem with any ZIP files from DAZ 3D, unless they are corrupted in some way.
    Before re-downloading, you would need to make sure and clear your Browser cache, otherwise you run the risk of just downloading the same bad file over and over.
  • Richard HaseltineRichard Haseltine Posts: 111,701
    What archive tool are you using to unzip? There were some items that had 0 byte pz2 or equivalent files to make thumbnails with instructions visible in the library, and the built-in Windows zip tool didn't like them.
  • XoechZXoechZ Posts: 1,102
    Yes, I am using Windows built-in unzipper (Windows 7 64bit) and the corrupted files are all .dsa files.
    In that case, try 7zip... http://www.7-zip.org
    I've never had it balk on zero byte file or other oddities.
  • SzarkSzark Posts: 10,634
    Ditto . But what many folks don't realise that Vista and Win 7 allows you to open a zipped file like any other folder, without extracting, allowing the files to be copied and pasted to another folder.
